- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Nothing at Home Depot....time to make my own on my 3D printer, in ABS.
I have drawn up two diameter pipes and separated them via the offset plane method. I now want to put a 45 degree transisional between the two pipes. I think 45 degrees is a threshold between needing supports, (scaffolding), on 3D prints, which is always a mess to clean up and a lot more printing time. Something to avoid whenever I can.
I did my due diligence with an online search. I came up with the idea that using the Loft tool is the way to do this, but I couldn't figure out how to use it without deforming my starting pipes. It seemed the tool would only allow me to select the facing edges but then generated errors stopping me from actually creating the loft. I want to maintain the originating spherical pipes as is and not have them affected by the transition. Attached is what I have and wish to preserve.
You help is, as always, greatly appreciated.
