Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Lofting Over Sharp Radius
9 REPLIES 9
Message 1 of 10
Ian.c.Stitt
299 Views, 9 Replies
I am trying to create an adapter that goes from a 2 3/16 to 2 1/8 in a 90 degree bend while minimizing the vertical distance it must travel. Basically I want the adapter to start turning direction and "adapting" it's diameter right off of the one plane to the other, but when I try to run a loft it gives me errors and says it is self intersecting. I cannot to save my life get this radius to work. Any help would be appreciated in getting this part to work and I have my sketch geometry attached below. Thank you!
9 REPLIES 9
Message 2 of 10
davebYYPCU
in reply to: Ian.c.Stitt
Sweep with Path and Guide rail may be acceptable.
More rails for a Loft if that does not work for you.  (Full solid with Shell)
Might help...
Message 3 of 10
g-andresen
try 2 rails for loft as @davebYYPCU recommended
1. Create  intersection points in the sketch and connect them with a spline or lines/fillets
2. loft with 2 rails
3. Shell from body
günther
Message 4 of 10
Ian.c.Stitt
Wonderful! Thank you guys very much!
Message 5 of 10
Following the screenshot in the OP you would not need a loft.
A sketch for a sweep profile and another sketch for a sweep path would be sufficient.
Message 6 of 10
g-andresen
in reply to: TrippyLighting
The diameters are (intentionally or not?) not identical.
günther
Message 7 of 10
TrippyLighting
in reply to: g-andresen
Hmmm..K, 3 sketches and a sweep with guide rail. Sketch 2 isn't really needed.
Message 8 of 10
Ian.c.Stitt
Can I loft along 4 rails to have the sides bellow out a little before sweeping down? And yes the diameters are not identical purposefully; is sketch 2 still not necessary?
Message 9 of 10
davebYYPCU
Yep, be careful what you ask for.  My original Sweep with Guide Rail did not make the bulge, just adjusted the diameters on the way.  The 2 side rails would likely need some tricky construction, unless you describe the limitations to the bulge.
Might help...
Message 10 of 10
Ian.c.Stitt
When I try to do the same intersect and connect with a spline it lets me select the circles to intersect but the purple snap points don't appear. I have tried in the existing sketch, a new one, and a new sketch on a plane parallel with the "bulge" feature. Not sure why I can't just do the same thing as before again just with a different shape of guide rail. Thanks for the help!
Technology Administrators
