Hello!
I am creating a bracket to be attached to a wing-strut.
When lofting profiles along two rails, a straight section of a profile (that should follow the contour of the strut) does not remain straight.
What am I doing wrong?
Thank you!
Solved by TrippyLighting. Go to Solution.
Please share the file for reply.
File > export > save as f3d on local drive > attach to post.
günther
Although I find the results not entirely satisfactory, I'd use a sweep to create side rails and then use surface lofts to create this shape.
Servus Peter!
I wonder why Fusion distorts the planar surface the way it does. I believe it has something to do with the linear distribution of cross-sectional areas ... it appears to be a logical glitch to me.
Thanks you for your approach! It works since the side-rails seem to fix the linear element.
In the meantime I had experimented with creating and outside shape and the extruding the inside shape to cut it out.
Who at SolidWorks would one need to talk to in order to understand this phenomenon?
Cheers,
Corvin
Fusion is a product of Autodesk.
SolidWorks is a product of Dassault Systems.
You are on the Fusion forum 😉
The explanation is easy. You need side rails to control the edge flow of the loft.
Sorry about the mix-up. No offence meant.
Understand your explanation (side rails) but still am intrigued what the program "is thinking". I am pretty sure it has something to do with cross-section area distribution along the length of the rail.
Thanks for your help!
Cheers,
Corvin
The program creates a loft according to the constraints you give it. If you don't constrain the loft to follow specific edges it won't. It will create its own arbitrary edge.
The last file is different from the first model. I would stay away from conic curves!
I would create the strut profile and Outside contour sketches first.
Then I would extrude (not sweep, I don't know what I was thinking) the Strut profile symmetrically to Bracket_Width.
Then I would create the loft profile sketches.
Intersect-projecting the strut profile and the outside contour into each profile sketch will create a line where the strut profile pierces through the sketch plane and a point where the outside contour pierces through the sketch plane.
Then constrain the profile splines trough those points.
Now you can loft with predictable results.
Another tip is to avoid offsetting spline curves. It won't have much of an effect in this design, but an have detrimental effect in other designs.
You can see the "artifacts" in the curvature of the offset spline:
Those aren't present in the original spline.
Very interesting detail, Peter!
This (partly) answer a question I have had. I create3d a complex wing shell with lofted wing profiles (which had splines) and tried to offset it. Quite frequently, the offset penetrated through the original surface. It seems that there is a challenge with contour smoothness on rosetted splines.
Thank you for your help!
Corvin
... dang autocorrect. ... answers a question ... offsetted not rosetted ...
