I noticed that there's now an option to select "local renderer" under the video tab.
Yet despite having a simple turntable style animation setup in the animation workspace, clicking render here only produces a jpg, png or tiff.
Can anyone explain either what I'm doing wrong, or why it's even an option if it doesn't work?
I just want to render a nice 20 second long 1080p 360 degree rotation of my model, and I have the time/computing power to do it locally, yet it seems that the only way I can do it is in the cloud. I'm a hobby user with long term health issues, so I'm too broke to afford the cloud credits. I was super pleased to see the local renderer option, but it doesn't seem to work.
I am able to publish an animation in the animation workspace, but obviously it looks like hot garbage compared to the proper render with HDR lighting. Please tell me it's possible?!!? ๐
I would almost believe hat's a UI snafu and it's not possible.
@jodom4 could you in=vestigate?
@welbot If you are interested in turntable rendering locally my suggestion would be to use Blender.
It might be daunting at first, but there is a wealth of tutorials available on youtube and the EVEE render engine utilizes the GPU and is several magnitudes faster than the CPU based local render engine in Fusion 360.
I'm quite proficient in several different 3d packages, including 3dsmax and blender, but I already like the way the render looks in Fusion, and I can't port the materials over to the other packages I have, so I figured if I could just do a simple turntable render, I might as well. Keeps things nice and easy.
As I said, I don't care about how long it takes. I would just let it go while I do something else. I'm stuck at home doing nothing already, so hardly an incovenience ๐
It's by no means essential to what I'm doing either, but upon looking, and seeing the option was there, I figured why not?! Finding out it only throws up a still image is just confusing though, so hoping to find out if I did something wrong, or if it's still not possible. Would be nice if we could render out simple turntables locally though. I don't need to be wasting your server power for my hobby stuff. Would be great to be able to throw up a turntable to show off on social media though. Much nicer than a still image.
Hello welbot
I am far from being a Fusion 360 Expert. I am in the same boat as you who has just asked myself the same questions you posed here. I see that this is an old thread which appears to not have been solved, so I thought I would add my 2-cents, for what itโs worth.
I just spent an entire day researching this topic and sadly found no information directly addressing the Video Tab; exactly what it does or how to use it. But, near as I can tell, the Video Tab is used to create rendered video animations of Motion Studies. You must have at least 1 Motion Study setup in the Design Workspace before the Video Tab can do what it is supposed to do, create a Play button in the rendered image preview window. You then use this Play button to render a video animation of the Motion Study in the cloud, which obviously requires Cloud Credits. And I donโt think there is a way to create a Turntable style video rendering in Fusion 360 without using Cloud Credits.
I currently have no designs with Motion Studies so, I have not been able to confirm this yet. But this How to Render an Animation in Fusion 360 : 6 Steps - Instructables webpage describes the procedures. This webpage, however, is not very well written but in combination with this How to render a motion study in Fusion 360 | Fusion 360 | Autodesk Knowledge Network webpage I was able to put the pieces together. I also found a few under 3-minute YouTube videos which attempt to demonstrate this procedure.
Good luck and I hope this helps.
T-SquareXY
Hello welbot
T-SquareXY
