I want to insert several components into one master assembly.
My workflow is:
What can I do to get a copy of my template and successfully inserting it into an assembly with linking?
Solved by ryan.bales. Go to Solution.
This is likely because you are on a personal hub and not team hub. Personal hubs do not allow for cross project referencing.
You'll need to setup a Fusion team hub to get this working: http://autode.sk/teamonboarding and it would be good to check out this for more information https://www.autodesk.com/products/fusion-360/blog/fusion-team-faqs/
That might be it.
I tried transferring but for whatever project I try to transfer I get an error message. A new team has been successfully created though.
I'm on a student license if that matters.
You were right about having to migrate to a team project. Now I can cross reference to my hearts content.
After creating the new team project I couldn't migrate my old projects at first, but it worked after 24 hours or so.
Thanks for your solution.
