When I use a joint on a linked assembly the joint can pull one component to the new place. I would prefer it to move the full assemly to the new place. Arguably you could say the original assembly needs to be fully constrained if you want to do this, however a assembly like a 3D PCB does not give joint functionalities.
Currently, when moving a PCB with Joint, only one layer of the PCB will move. It did not do this before.
The workaround is simple; in de main assembly select the PCB component using the browser, then make it a rigid group. (Assemble > Rigid Group)
It is rather unfortunate I will need to do this to all PCB's. If the current bahaviour is by design, could the 3D PCB then be created as a rigid group by standard?
Also notice all previous projects have to deal with this new implementation. So all PCB's that are placed using joints are now out of place. (Well, most layers anyway.)
Kind regards
