Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Latest Lab Admin Update Needs macOS 10.14?
13 REPLIES 13
Message 1 of 14
ENTCity
1792 Views, 13 Replies
I just installed the mandatory Lab Admin version update v2.0.7805 that came out today.  It installed without an issue, but now when trying to run the application, it will not launch and pops up that "You can't use this version of the application with this version of maOS.  You have 10.13.6 but this application requires 10.14 or later."
Is this actually correct?  All the system requirement pages say 10.13 High Sierra is compatible?  If we actually need 10.14, why did the installer actually run instead of giving an error BEFORE installation?  And, why would you change that requirement in the middle of a semester?
13 REPLIES 13
Message 2 of 14
lance.carocci
in reply to: ENTCity
@ENTCity, I apologize for the inconvenience! This is not intended, we do indeed support 10.13.
We are looking into this issue now, and will provide an update as soon as possible.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 3 of 14
ENTCity
in reply to: lance.carocci
Lance,
Great.  Glad that's the case.
Message 4 of 14
lance.carocci
@ENTCity, this will be addressed in a future hotfix currently in development.
In the meantime, could you please try running the Fusion shortcut directly from the ~/Application directory and let me know if this changes the outcome?
Thank you,
Lance
Lance Carocci
Message 5 of 14
ENTCity
@lance.carocci  Yes, the shortcut in ~/Applications allowed it to launch.
Uninstalling via a drag to the trash and empty, then reinstalling does not change anything.  However, on one of the machines that I ran the Fusion 360 Cleaner on, it can now install and be used.  This did not work on the other machine I tried.
Message 6 of 14
imstester
I'm seeing this as well with the regular desktop program after auto-updates.
How long before there's a fix for this??
Message 7 of 14
colyn55
ok running from application directory worked for me while they fix the issue
Message 8 of 14
Howdy, I'm having the same problem. When I try to launch Fusion 360 from the dock i get this message
"You have macOS 10.13.6. The application requires macOS 10.14 or later."
and when I try to launch from the applications folder or the Launch Pad I get this message:
"Check with the developer to make sure Autodesk Fusion 360 works with this version of macOS. You may need to reinstall the application. Be sure to install any available updates for the application and macOS.
Click Report to see more detailed information and send a report to Apple."
I uninstalled it and reinstalled it but my luck has not improved. Any insight into the fix would be fabulous. Thanks.
Message 9 of 14
risototh
This solution worked exactly one time. I wanted to run the F360 today, it started, but in some meta-state. Some icons were "strange" and it freezes with CPU in the sky... I killed it, and wanted to start it again, but without luck, the 2.6 GB binary (or package) deleted itself... Restoring it from the Time Machine does not help. So, for now, I'm without the Fusion 360, as I cannot update to 10.14 (or at least not now). Jut a notice, the 10.13.6 is still supported by Apple...
Message 10 of 14
risototh
No news at all?
Message 11 of 14
ENTCity
@lance.carocci Any word on this?  Is the next patch that's scheduled on 4/13 supposed to fix this?
Message 12 of 14
lance.carocci
@ENTCity this should be fixed in the current release of Fusion.
Lance Carocci
Message 13 of 14
I am still able to use Fusion but have the following message in a message bar under the toolbar: "Fusion 360 will require macOS 10.14 or higher after our 2021 April update. Check the Mac App Store for OS updates." So will fusion continue to support macOS 10.13 for the foreseeable future?
Message 14 of 14
lance.carocci
@Anonymous, we have already dropped support for 10.13. Existing installations will stay on the last version that was compatible, but new installations and the latest updates will require a supported OS.
Lance Carocci
