Dear community and support team,
I try to design an item with large measurements > 10 m. As I do so the measurements are displayed in a cryptic way.
12m = 1.20E+04, can I do something to fix this?
Kind regards,
Philipp
Solved by James.Youmatz. Go to Solution.
Solved by jeff_strater. Go to Solution.
This is scientific notation. You can control when values are displayed in this form using this preference:
Hi @philippmartennatter ,
This is known as scientific notation. These values can be adjusted in your Fusion 360 preferences under the Unit and Value Display. You will want to adjust Scientific Notation above and below.
