Hi All, need some help creating some motion joints in the attached simple machine. The crank handle rotates the disk and swings the Yoke left and right. All help appreciated.
Solved by jhackney1972. Go to Solution.
You need a Pin Slot joint between the crank handle and a side plate.
The yoke as you call it needs a Revolve and not Cylindrical Joint.
Might help.....
I used a Tangent Relationship to connect the rotating pin the the Yoke. This could have been a Pin-Slot Joint but it is a little more difficult to apply in your case. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Hi John, Your solution worked perfectly, I did not know there was a tangent relationship in the menu dropdown. Thanks So much..
