Issue with flat pattern view orientation X bend direction
duomaq
Observer
Observer
duomaq
Observer
Observer
Hello Dear,
I'm facing an issue when I try to get bend directions in drawing mode.
I have a sheet metal object, then I created a flat pattern.
After that, I switched from Design to Drawing mode and placed 2 base views from my flat pattern. One for front view and another for back view.
I put the bend notes in both and the result is that the orientation of the bends are the same, but it must not to be.
For example, if one is down 90° the other must be up 90°.
It's a bug ? What can I do to not be mistaken by this ?
(It seems that the front view is the correct one)
Ivan Alves
Brazil
johnsonshiue
Hi!  It should work. If possible, please share the sheet metal f3d file here. I would like to understand this behavior better.
Many thanks!
Software Test Engineer
liang_chen
Hi duomaq,
Thanks for the feedback. I can reproduce this issue in a normal SheetMetal case, and it has been reported as internal ticket(FDWG-15860) to Dev team for investigation.
Fred
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
