Errno13 when installing Fusion 360 on Mac
heliyuan.2004
Observer Observer
heliyuan.2004
Observer
Observer
I encountered "[Errno 13] Permission denied" when installing Fusion 360 on Mac (with M1 chips and macOS 12). I have tried the solutions on the relevant troubleshooting page, including restarting and disabling the anti-virus software. However, it still failed and I got the same Errno message each time. Attached is the log. I would appreciate it if you can do me the favor.
dsouzasujay
Hi @heliyuan.2004
Try to change the permission settings via Terminal.
  1. Open terminal.
  2. Switch to root user with the sudo command: ’sudo -i'
    • Note: This requires the admin password
  3. Navigate to the user’s application support library. In terminal, type cd /Users/<username>/Library/Application Support/‘
  4. Change permissions for the Autodesk folder and its contents inside Application Support to read, write, and execute using chmod command: 'chmod -R 777 Autodesk/‘
  5. Check ownership of /Users/<username>/Applications folder, if the folder is owned by root, grant logged in user and others full access rights to the folder using the command: 'chmod -R 777 ~/Applications'
  6. Finally, relaunch the installer.
  7. If the installer would still fail please change the ownership of the 'Applications' folder with the below command running from a Terminal (it may prompt for password input) then do the install:
           sudo chown <username> ~/Applications
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
sikandar_ilyas
Hi @heliyuan.2004
Before trying out the solution provided by @dsouzasujay , Can you please help to get output of command ls -l for the directory /Users/<username>?
Here are steps to follow:-
  • Go to terminal
  • Navigate to directory /Users/<username>
  • Run command ls -l
  • Capture output from command prompt
