- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Thanks for reading my post. I'm out of ideas on how to fix my problem, and I'm really hoping someone has a simple answer that I missed!
I have been making a pendulum clock by designing it in Fusion 360, and then printing all the parts on my 3D Printer. However, the frame is much larger than my printer bed, so I cut the frame into pieces in Fusion and printed them separately. I added notches and holes in the split frame pieces so they would "snap" together once printed, and thus will become a sturdy, solid frame.
Getting the pieces to "snap" together is where the issue comes in.
In Fusion the pieces articulate perfectly. The 6mm notch fits right into the 6mm hole, but that doesn't work in the real world once the parts are fabricated. All parts need a little wiggle room through either having a slightly larger hole, or slightly smaller notch.
Is there a way in Fusion to automatically add extra space around all surfaces that articulate together, so that they actually fit together once fabricated?
Every space that touches another needs a little buffer room. This is true even with the most precise settings on my 3D printer, and is true when I make things with my amazingly accurate CNC machine. Currently I'm modifying each surface that snaps into another one at a time, and it is exhausting. Example being that the hole stays 6mm, and I use the "Q" (offset faces) function to make the notch have only a 5.8mm diameter.
- Screenshot 1 you see a few of the pieces fitting together in the geometrically perfect world of Fusion.
- Screenshot 2 you see the holes created to receive the notches from the other piece.
- Screenshot 3 you see the notches meant to go into the holes.
- Picture 4 is the front of the actual printed and assembled parts.
- Picture 5 is the back of the actual printed and assembled parts.
screenshot 1 - Multiple pieces of frame fitting together perfectly
screenshot 2 - One piece with added holes to fit with another part
screenshot 3 - Part with pegs to go into the holes of the other part
picture 4 - front of assembled frame parts
picture 5 - back of assembled frame parts
I am also open to other ideas that accomplish the same goal. I used the pegs and holes (of different sizes) because I could make it so them only fit one way. This helped reduce the chance of incorrect assembly when I was looking at around 75 different pieces for the whole clock. I ended up having to drill the holes slightly larger on all pieces, and sand the flat surfaces so the pieces fit flush.
I apologize if this is not the correct forum to post this question. I appreciate any help anyone can offer!
Thanks!
