I have been invited to access files from a project in fusion, I can access the project online but cannot see the drawings on there and I cannot see the project in fusion itself to save drawings and also to access necessary files that are needed.
thankyou.
It's probably your project access settings. Can you send a screenshot of the settings? Or at least verify that the project admin has given you "Editor" permissions.
Try logging off and on
Still if you face any problem, send a complaint to the project admin.
But before you do that just have a look at your project settings and preferances in Fusion 360.
Even I faced a similar situation recently.
What have done is, I just gave a complaint go the project admin and some how it was solved.
