Invalid HTML was found in the message body
bharathkumaran26
Message 1 of 10
bharathkumaran26
Hello everyone !
I couldn't attach screencast even after it was published public. The error message shows like,
"Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied"
Is there any bug or am I supposed to do anything to get rid of that issue. I have attached a screenshot for your reference. Kindly waiting for a valid reply.
Thanks & Regards,
Bharath R K
  • HTML
Replies (9)
Message 2 of 10
g-andresen
Unfortunately, this is a message that appears irregularly from time to time.
günther
Message 3 of 10
bharathkumaran26
Hi @g-andresen
Yes actually, I am getting this issue for the past few days. And there is no proper solution for this in Forum too.
Kindly let me know, If there is any way to resolve this issue.
Thanks & Regards,
Bharath R K
Message 4 of 10
g-andresen
This is an error message that has been posted by many users.
Unfortunately, there is obviously no solution "against" it yet.
günther
Message 5 of 10
bharathkumaran26
Hi @g-andresen
Hope this technical glitch get resolved soon. Let me know if you find any solution for this.
Thanks & Regards
Bharath R K
Message 6 of 10
chrisQX8DX
wow, i can't believe this still hasn't been fixed ... how do people manage to insert screencasts into their messages ? Is there a workaround ?
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Message 7 of 10
TheCADWhisperer
This issue has been unresolved for many years.
There are two work-arounds:
1. Post link rather than attempt to embed the code.
2. Achieve Autodesk Expert Elite status (and I am not sure that it works for all EEs).
Why oh why they haven’t removed the PAST A SCREENCAST box until they figure out how to make it work I’ll never understand.  The EEs know how to copy the html so they don’t need the box.  It only frustrates everyone else because it doesn’t work and doesn’t give correct error message (it should say, “You do not have elite permission for this operation, post link instead.”)
Message 8 of 10
chrisQX8DX
re 2. -> that's just weird. it seems to me that being able to easily show through a screencast would be equaly if not more helpful to someone posting a problem/question than to an expert replying. it would for sure cut down on the 'can you share the file' requests (which in a commercial engineering context is most of the time out of the question) and make it easier for people not fluent in english to show a problem/question/issue.
Message 9 of 10
g-andresen
A few years ago, an AD employee told me (off the record) that embedding screencasts via HTML code is a security risk and therefore only allowed to a certain group of people.
Since then, I have been linking to my screencast.
Various contributions in this matter (also in the screencast forum) were not acknowledged at all or with questionable reasons.
günther
Message 10 of 10
justin_a_laviolette
Not an elegant solution, but i click the HTML button and start deleting things until the message posts. 🙈
