using a windows7 machine but tried it on a laptop with windows10 and same thing. These CAM operations were working. I created a new setup today and now none are. I opened a different file and the CAM operations seem fine. Can anyone suggestion a solution please?!
Solved by tonality. Go to Solution.
Could you export and share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your repy
I solved the problem by uninstalling and reinstalling Fusion. Seems to be working now. Thanks.
