Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Internal CAM error
7 REPLIES 7
Message 1 of 8
chaikenm04L65CL
440 Views, 7 Replies
Internal CAM error
I just updated Fusion 360 today  and now I have been getting this error regardless of what file or shape I am trying to generate 2D contour tool paths.  Has anyone run into this error?
Enabled feature flags: online-system-library setup-sheet-configurations setup-sheet-viewer tool-library-v4-release
Invalidated: Generation failed
Error: Internal CAM kernel error. Please report through your support channel.
Labels (2)
7 REPLIES 7
Message 2 of 8
I too am having the same problem
can't make any Toolpaths without getting this error:
Enabled feature flags: online-system-library setup-sheet-viewer tool-library-v4-release
Message 3 of 8
bmcihk
in reply to: chaikenm04L65CL
Im having the same issue after software update, did anybody find a solution on how to get back to business?
Message 4 of 8
Yep, known bug. Remove any special (non-ascii) characters from the tool name
Seth Madore
Message 5 of 8
TJS01
in reply to: seth.madore
Same issue here.  Gotta love those updates and super helpful error messages!
Message 6 of 8
All; Restart Fusion, grab the latest update that rolled out today to address these issues, restart, and this should be resolved.
Seth Madore
Message 7 of 8
I actually found a post regarding the problem. In the last update there is
an error in how the program deals with some characters in the alphabet.
They recommended making a copy of your desired tool and simplify the name
to jot contain any Cyrillic notations. I use the Amanda tools library. I
stripped the 46200 tool down to just that number and everything works fine.
They say they are working on a fix. Hope that helps.
Message 8 of 8
All; this has been fixed in a recent update. Restart Fusion to trigger the update, restart again to consume the update.
Seth Madore
Technology Administrators
