Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Insert Derive Crash after Insert Derive success
8 REPLIES 8
Message 1 of 9
Ivan_Nuno
862 Views, 8 Replies
I've been able to repeat this crash almost every time. I will post a screencast when I have a second.
Open existing design #1
Insert - Derive - open existing design #2
Choose component from browser of design #2
Insert Derive is complete
Insert - Derive - open existing design #3
Choose component from browser of design #3
Hit Ok = Crash
I can save in between - let it crash, and then insert derive from design #3 after restarting Fusion and it works. I can reverse the order with the same effect. I can use any component from any design with the same effect. I can try to insert derive into any file with the same effect.
Patrick Beseda
Twig Custom Builders
Laguna Smartshop II SUV
Tags (3)
8 REPLIES 8
Message 2 of 9
Ivan_Nuno
in reply to: Ivan_Nuno
To add to the fun - I'm now experiencing some odd behavior.
I went back to one of the designs that had components derived into a model I was working on. I changed a user parameter - saved, closed, and went back to the model to update the link.
It recognized the change and prompted me to "get latest." I was met with "1 Component is still out of date. Run the Get Latest command again."
When I edit that derive feature from the timeline - it is referencing the OTHER model that I had "insert-derived" components from.
Screencasts incoming.
Patrick Beseda
Message 3 of 9
saito.kh
Hi @Ivan_Nuno,
Thank you for posing in the community!
Sorry to hear that!  I created some files containing some components and tested this; then I was unable to recreate the behavior on my end.
I would like to take a closer look at this, so would you mind sharing the files with me?  If it is fine with you, could you create a public link to the design files and post in this thread?  You might like to send it to me via email (kanehiko.saito@autodesk.com).
** Please make sure to enable the "Allow item to be downloaded" option in the dialog box.
Also I would appreciate your creating a Screencast!
If you have any questions, please let me know and I'm happy to help!
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 4 of 9
Ivan_Nuno
in reply to: saito.kh
Here is where it happens on the project I was working on. I'll work on getting files exported.
Patrick Beseda
Message 5 of 9
saito.kh
Hi @Ivan_Nuno,
Thank you for creating the Screencast!
In the video I saw a warning message in the "Cabinet 3"  file - the "Kitchen Drawer" component seems to have an update.  Did you try to run GetLatest before deriving the file?
Thanks.
Kanehiko SAITO
Message 6 of 9
Ivan_Nuno
Sorry for the delayed response - it's not as predictable of a crash as I thought.
After "Get Latest" these files still crashes. With new files, it is hit or miss on the crash - and the order in which things are saved, opened, derived, closed, etc.
Patrick Beseda
Message 7 of 9
saito.kh
Hi @Ivan_Nuno,
Thank you for your update!
Sorry to hear that trouble is still persisting.  Can you please share a public link to the design files with me so that I can further investigate this behavior on my end?
You might like to post the link in this thread or send it to me via email (kanehiko.saito@autodesk.com).
Please keep me updated!  If you have a question, please let me know.
Thanks.
Kanehiko SAITO
Message 8 of 9
Ivan_Nuno
Here's a new screencast and links to the files. Let me know if I can provide any more info. Thanks!
Cut File: https://a360.co/2T1XBok
Cabinet 1: https://a360.co/2T1Ws00
Cabinet 2: https://a360.co/2T2713d
Patrick Beseda
Message 9 of 9
saito.kh
Hi @Ivan_Nuno,
I am very sorry for the delay in responding! - I was out of office until today.
Thank for your sharing files and creating the new Screencast!  I just downloaded those files.
I will check this on my end and will get back with you once I have something to share!  Thank you for your patience.
[Edit]
Again I appreciate your sharing all the information about the issue!
I was able to recreate this on my end.  I've logged a bug with our development team for the further investigation. (internal ID: FUS-45855).  I will update in this thread once I hear back from the team!
I apologize for any inconveniences this may cause you - we appreciate you bringing this to our attention!
I also see it works if I would save the file after inserted "Cabinet 1" and then reboot Fusion as you shared in the very first post.
Thanks.
Kanehiko SAITO
