Fusion Support
Report issues, bugs, and or unexpected behaviors youā€™re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Incorrect date format
2 REPLIES 2
josh_l
145 Views, 2 Replies
Hi there,
Why does Fusion not follow my system's date format? I'm using macOS. My date format is dd/mm/yyyy but the Data Panel only shows dates in mm/dd/yyyy. Is there a setting buried for this somewhere?
Cheers,
Josh
2 REPLIES 2
lance.carocci
in reply to: josh_l
Hi @josh_l, this should be fixed in a future release.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
josh_l
in reply to: lance.carocci
Thanks Lance, it appears this is now fixed. Much appreciated!
