If I create a sketch and insert a point in it and then export as a DXF file, the point does not come with in the DXF file. Am I doing something wrong or is this not supported in Fusion? I found a topic from several years ago where someone had the same issue. Has this been changed at all? I need points to tell a cnc plasma cutter where to spot marks for holes.
