In the XZ plane, below the xy plane the z axis is positive.
Willow102
Willow102
Hi there,
               When creating a sketch using the origin plane  I've noticed in the XZ plane, below the xy plane, the z axis is positive. Is this normal?
Any help would be much appreciated.
Thanks!
seth.madore
If I'm understanding your question correctly, this can be controlled with this option:
Seth Madore
Willow102
Hi Seth,
             Thanks for your help. I've I've found changing the default modeling orientation doesn't solve the issue. I didn't attach a file in my original post. I'll attach one below. Cheers
jhackney1972
You need to explain what you doing or what to achieve.  In the video you can clearly see that specified distances below the X-Y plane are negative in value.  Please clarify what you are looking at with a video.
Negative Below XY.mp4
Video Player is loading.
Current Time 0:00
Duration 0:40
Loaded: 0%
Stream Type LIVE
Remaining Time 0:40
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    John Hackney, Retired
    jeff_strater
    "Is this normal?" short answer:  yes.  In "Z up" orientation, the XZ plane is "funny".  For more explanation, see this thread:  why-is-my-sketch-text-appearing-upside-down
    Jeff Strater
    Engineering Director
    Willow102
    Hi Jhackney1972. Thanks for the demo. I'll try and explain what I'm confused by. The Z axis's number-line-digits are negative above the X/Y plane. I'm wondering if the appearance of the Z axis's number-line-digits appear negative above the X/Y plane is the Fusion 360 default.
    Also, (for a sketch created on the ZY plane) to move the sketch geometry up a negative value is required. I hope that helps.
    Seth.Madore I now see your solution was correct. Changing the default model orientation does fix this issue.
    Gabe
    Type a product name
