Announcements
Import STL file and how to generate a drawing
Bernd_CAD
Bernd_CAD
Hi, I have some STL files which i imported into fusion 360. I created a fusion design. Now I would like to generate a drawing to put some measures on it. But that's not possible. Even if I export them as a STEP or IGES and import them again. Message: Contains no bodies.
What can I do to get a solid body? Thanks again for your help.
paul.clauss
Hi @Bernd_CAD
Thanks for posting! The Drawing environment can currently only use solid brep bodies from Fusion 360 - mesh bodies from an inserted STL file will not be included in the drawing.
You should be able to get the mesh bodies converted to brep solids by using the procedure at this link. As mentioned in the article, you may need to consider reducing the mesh if it is too large for Fusion 360. After converting the mesh to a solid body, you should see the solid body included in the drawings.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
RichardmBernstein
I usually get full body scans or highly sculpted .stl's, currrenly I have had no luck with converting these objects to get them into drawings based on their file size.  Is there any new way developed to handle this type of issue, extension or add-on?
rjmelohn
Observer
Observer
YES, PLEASE!
Is there an answer to this issue?
jhackney1972
The answer is given in Message #2 of this post.  If you have a specific STL file that you are having issues with, please attach it to a reply post.
John Hackney, Retired
rjmelohn
Observer
Observer
The issue is that all of the .stl's I have to work with are well over 10K triangles, and decimating them to allow for a BRep to solid change is not an option for both detail loss and the amount of time that would take.
TheCADWhisperer
You can create 2D drawings of 3D stl meshes in Autodesk Inventor Professional.
Attach example file here if you would like to see illustration of the functionality.
