Message 1 of 10
I am working on a sketch, and I create construction lines as guides. On those usually I have other lines.
Now it makes it very difficult to pick the actual line is tools like Move. I obviously don't want to move the construction line.
Therefore I right click on the construction line and fix it. Now if I use the Move tool, it only pick my actual lines, but not the construction line.
But if I use the Rectangular Pattern tool, that does not appear to use the same logic. I can happily pick my fixed construction line which does not make sense. At least I would expect these tools to work the same way.
Could this be a bug?
