I'm trying to make a garage door track, but I can't assemble it correctly...
This is driving me insane.
I have a garage door track.
In that track I have a wheel with an axle.
That track turns 90 degrees, but I can't seem to direct my wheel to follow the path of the track beyond a slider that is constrained to a single axis. The wheel component will slide along the straight track, but as soon as the 90 degree 12" radius track is reached, it stops and won't follow the track.
I can get the wheel to slide back and forth in a straight track as a slider joint, but when it approaches the 90 degree turn, it just moves through it and continues on the same path. If I create a contact set for the wheel to the track, when it gets to the 90 degree turn it just locks up.
How do I make a garage door that will open and close following the track path?
