Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
I'm looking to create a cube with a fixed top and bottom size
1 REPLY 1
246 Views, 1 Reply
Newbie here.
I need to create a cube that has a constant base of 22mm x 22mm and a constant top that is 21mm x 21mm with a height that can be variable.  Can someone direct me to a tutorial or give me a vague idea on how to do this?
Thanks!
1 REPLY 1
davebYYPCU
Not a cube.
2 sketches, fully constrained squares,
2nd sketch on an Offset Plane.
Loft the 2 Sketches
With Timeline turned on, Right Click the Offset Plane icon in the Timeline,
Select Edit Feature, change your Offset value, press Ok.
Might help...
