Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
I can not export the drawing to pdf or dwg
4 REPLIES 4
OHchirinos
1790 Views, 4 Replies
OHchirinos
Hi:
I can not export the drawing :  https://a360.co/2M8xYP2 to pdf or dwg. does not working menu options.
PLeas Help me
Oscar
Hi:
PLeas Help me
Oscar
4 REPLIES 4
paul.clauss
in reply to: OHchirinos
paul.clauss
Hi @OHchirinos
Thanks for posting! I was able to download your file and had not problems exporting PDF or DWG formats - I've attached both of these to this forum thread.
What behavior are you experiencing when you attempt to export the drawing in PDF or DWG format? This could be a permission related issue - are you certain that Fusion 360 has read and write permissions in your system? If you are working on Windows, does the same issue occur if you right click the Fusion icon and select "Run as admin" when launching the program? Do you experience the same problems with any drawing file or only particular ones?
I hope this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Hi @OHchirinos
Paul Clauss
OHchirinos
in reply to: paul.clauss
OHchirinos
Thank you Paul.
Ok. I can see my software is the problem.
I attached two pics. As you can see pop up windows for PDF and DWG export are working, but don´t write the files.
 How can I correct this?
Regards
OscarDWG POP Up windowDWG POP Up windowPDF POP Up windowPDF POP Up window
Thank you Paul.
Regards
paul.clauss
paul.clauss
Hi @OHchirinos
Thanks for posting. What happens when you confirm the creation of the DWG or PDF? Is the file simply not written?
Are you working on a Windows Admin account, as Fusion 360 requires? Does this behavior continue occurring if you open Fusion 360 by right clicking the desktop icon and selecting "Run as administrator"?
Is there anything unique about how your Windows profile is set up?
I'd also be curious to know if the files save correctly if you try saving to a different location.
Paul Clauss
Hi @OHchirinos
Paul Clauss
OHchirinos
OHchirinos
Hi Paul. You make a goal.
"I'd also be curious to know if the files save correctly if you try saving to a different location."
I tried save to a different location and the files were written.
I will review what happend to the original directory.
Thank you
Oscar
Thank you
Oscar
