Hi, I need to select center of mass, yet there is no way that I have found yet that allows me to do so. I have the center of mass on the object, I just need to be able to actually select it as a point. Is this possible?
Solved by jeff_strater. Go to Solution.
Solved by ryan.bales. Go to Solution.
It's mostly specific to whatever function you are doing. What are you selecting it for?
On trick on something like Inspect > Measure is to use click-and-hold to bring up the selection window. Then you can pick it no issues. It's also selectable in the browser as i have it shown expanded:
Hi, thanks for that, but is there any way to select it as a point for a sketch?
Not directly no, you'd need to pull the data manually and create the plants/axis/points etc.
To my knowledge its still mostly a visual reference and a dimensional point. @jeff_strater is this still correct?
Correct, the current center of mass icon is very limited - you can see it, and use it in Measure, but that's the extent of it...
You can run the script created by ekinsb here:
I ran across your forum post where you desired to place a point on the center of gravity (COG) of a body or component. I recently wrote and recorded a blog article where I do this very operation. I would like to invite you to take a look at the article and video.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Implementing jhackney1972 's solution would be ideal. A simple point created at the COM icon should be trivial to code and very helpful.
