After I drew a circle and extruded it .25 in thickness, I went on to apply an engraving. But I need to change the thickness of the disk. I can't seem to see how to do that. I humbly ask for help.
Solved by saito.kh. Go to Solution.
Hi @Anonymous,
Thank you for posting in the community!
Did you try to right-click on the Extrude icon in your timeline and select "Edit Feature" in the menu?
Then, the EDIT FEATURE dialog would be popped up and the value of thickness (Distance) could be edited there.
I hope this helps.
Thanks!
