Fusion Support
How to align sketch grid with component or model axes ?
6 REPLIES 6
2180 Views, 6 Replies
Dear forum members,
The grid of the first sketch on a component is at an angle of 26,6 °. Is there a way to make it parallel ? If so, how ?
The problem I have is the same as described in http://help.autodesk.com/view/fusion360/ENU/?caas=caas/discussion/t5/Fusion-360-Support/How-to-align...
Dear forum members,
6 REPLIES 6
ryan.bales
ryan.bales
Autodesk Support
Autodesk Support
This can happen with imported parts and files. I would just delete that sketch and create an offset plane on that face with a zero offset. Then create a sketch on that plane. Since this model has no design history is referenced face or plane is fairly unimportant.
Ryan Bales
Fusion 360 Product Support
Ryan Bales
TheCADWhisperer
TheCADWhisperer
Sketch on the Origin Planes. (Search Google - The BORN Technique.)
Robust and predictable.
Both methods worked.
The grid lines were correctly oriented on sketch based on a contruction. Drawback : more clutter (the construction plane)
The grid lines were correctly oriented on the sketch placed on an origin plane. That also has drawbacks, which I will discuss in the thread forums.autodesk.com/t5/fusion-360-support/how-to-edit-features-without-design-history/td-p/9646494.
TheCADWhisperer
TheCADWhisperer
@Anonymous wrote:
1. Drawback : more clutter (the construction plane)
2. That also has drawbacks, which I will discuss in the thread forums.autodesk.com/t5/fusion-360-support/how-to-edit-features-without-design-history/td-p/9646494.
1. Are you interested in the obtaining correct geometry or in pretty screen?
2. That is a different issue, different thread discussion. I was only addressing one issue in this thread.  Each solution depends on the problem description.
in reply to: TheCADWhisperer
I am interested in having a correct geometry. I don't mind a pretty screen. I do mind clutter.
GabeTL
GabeTL
I know this is probably a dead thread, but for anyone who stumbles upon it in the future, creating a construction plane with a zero offset worked for me.  I had an issue where the grid in the sketch would show the Y axis flipped, which would make an exported DXF of the sketch rotated 180°.  This happened if I used the top surface of the part as the sketch plane, or if I used an origin plane.  Making a zero offset construction plane on an origin plane aligned the grid correctly.
