New sketch, create a line.
Click coincident, click the line, click the origin.
Hover any point of the line, or the origin, and no marker shows up showing the coincident constraint.
It seems to be impossible to remove it?
Solved by davebYYPCU. Go to Solution.
Select the Origin,
Right Click - in the menu
select Delete Coincident,
will delete all of them.
Might help...
I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
John Hackney, Retired
