Fusion Support
How Do I Remove This Edge?
1 REPLY 1
ryanasher1998
223 Views, 1 Reply
How do I remove the edge highlighted blue? Basically what I'm trying to do is make the tab and main part of the body one face. Using the merge feature doesn't work. I have tried simply right clicking it and deleting it but that does nothing.  I was able to delete the opposite edge on the outside of the tube but not the inside. I don't even know how I did that to be honest...
I'm very new to Fusion. This is a customer's file, I did not make it. I believe it was made in Solidworks.
Also, does anyone have recommendations/resources for learning Fusion specifically for tube/pipe fabrication? Looking to learn how to build hand railing, roll cages, etc. Mostly with round and square tube but occasionally I'll be working with rectangle tube, L channel and U channel as well.
Tags (1)
1 REPLY 1
g-andresen
in reply to: ryanasher1998
please avoid double posts
günther
Technology Administrators
