Fusion Support
How do I download my project files to my computer for a backup
5 REPLIES 5
5998 Views, 5 Replies
Is there a way to download your project files to your computer or other source as a back-up in case your account or cloud files get lost?
5 REPLIES 5
pawel.potyrala
Hello @Anonymous,
thanks for posting. The following article provides steps on how to create a backup of a Fusion 360 design: How to make a local archive (back-up) file in Fusion 360
Usually, the designs need to be backed up individually.
If none of the Fusion 360 data in your project contains references to other Fusion 360 designs, a quick alternative might be the following:
  1. Clear local user cache for Fusion 360: How to clear local user cache in Fusion 360
  2. Open all the Fusion 360 designs from a project in Fusion 360 Desktop App
    Alternatively: select all the designs from a project in your data panel, right-click and "Add to local cache"
  3. Create a backup of the files by copying them from your local cache folder "F", see: How to locate locally cached files in Autodesk Fusion 360
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
in reply to: pawel.potyrala
Pawel,
The first link does not work to take me to the article.  Can you resend?
pawel.potyrala
Hi @Anonymous,
thanks! I fixed it already. Just in case, here it is once again: How to make a local archive (back-up) file in Fusion 360.
Best regards,
Paweł Potyrała
Pawel,
Thanks!
jonlL7WDR
All,
Thank you for this.  I am trying to do a full migration of all my working files and I was wondering if there is a bulk way to do this.  I have several thousand design files so downloading each is restrictive.
thanks,
Jon
