Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Hinge movements not working when two are attached
4 REPLIES 4
gabriella_seto
256 Views, 4 Replies
I'm trying to get my hinge movements to work for an assignment. The hinges are only working when I attach one but when I try attach a second one to the same door,  the movement doesn't work anymore and I have no idea why. I've linked an image below of the hinges I'm using but I can't find any solutions that uses the same hinge that I am using. Can anyone please explain why and how do I fix this problem? Thank you!
Labels (1)
4 REPLIES 4
g-andresen
in reply to: gabriella_seto
Please share the file.
File > export > save as f3d on local drive  > attach to post
günther
thanks for the reply, i have figured it out now 🙂
g-andresen
Please be so kind as to describe what the problem was, so that future readers can also benefit from it.
günther
I was trying to attach two hinges to a door. At first, the movement was only working when I had one hinge, and when I added the second hinge to the door the movement no longer worked. I found a video on youtube which was not really helpful but I tried it again and it seems to work now. I've accepted the current state of the hinges, but they still seem to be glitching a lot and I'm not sure how to get a smoother animation. Here is the file anyways if someone knows how to improve this.
