It was previously possible to fix fusion 360 scaling for high DPI monitors using the windows compatibility settings by selecting "override high DPI scaling behavior: Scaling performed by Application". With the newest update, this no longer works. We are now stuck with incredibly blurry or blocky icons, text, and models. Is there any fix for this?
Solved by lance.carocci. Go to Solution.
On Windows 11 4k monitor, 200% scale, Fusions looks great with the preview enabled. But the right click menu renders who knows where and it appears to just flash under the cursor. I saw the menu appear correctly on one of my other monitors so it is working, just misplaced. Back to disable preview again and deal with the blurry icons and text. Such a black mark on Autodesk reputation.
@aaronblankenship There should be significant improvements to the high DPI experience in an upcoming release. One area of difficulty has certainly been mixed-DPI multi-display environments, and it sounds like this might be what you are encountering.
Could you please share a recording or screenshot of the behavior? I can check if this issue is known.
I tried this on both multi-monitor and single, restarting the app between tests. Win11 1080 TI with latest studio drivers.
Notice that the menu shows up as I stop the recording....
