Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Help with possible hole command anomaly..
8 REPLIES 8
Message 1 of 9
Sean3073
303 Views, 8 Replies
First I signed an NDA for the part, so can't post, wish I could.
The issue. I used the hole command to generate a hole at 0.812 as seen with pic 1.
Then I measure the hole and get a different number. See pic 2.
I produced a print and get the same wrong measurement. See pic 3
What am I doing wrong?
Respectfully,
Sean
Tags (2)
Labels (2)
8 REPLIES 8
Message 2 of 9
g-andresen
in reply to: Sean3073
Please create a sample file containing only one body with hole
günther
Message 3 of 9
jeff_strater
I was not able to re-create this on a simple model.  Without your model, it will be very difficult to determine what might be wrong.  Can you cut down the model to a small subset, including the hole, that you can share?
Jeff Strater
Engineering Director
Message 4 of 9
Sean3073
in reply to: jeff_strater
I would love to, I just have no idea how to maintain the construction
history (minus the rest of the model for NDA purposes) and only give you a
small piece of the model. Or put in another way, I can cut out most of the
model but the time line will allow reconstruction. dumb NDA's. I am
chipping away at it though. Sean
Message 5 of 9
g-andresen
If it's a general problem with you, create a new file for a simple body with a hole.
günther
Message 6 of 9
Sean3073
in reply to: g-andresen
It seems to be just with me and specifically that model I have created. I
have done several new models (simple square block) with the same hole and it
comes out normal, I just don't understand why it doesn't like the complete /
original model I have built. Sean
Message 7 of 9
HughesTooling
When you take the measurements have you rolled the timeline back to just after the hole command? Just wondering if you've modified something after adding the hole.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 9
I just imported both of your images into Fusion, calibrated and positioned and it looks like the top face is different in the second image.
Mark Hughes
Message 9 of 9
Sean3073
in reply to: HughesTooling
Found it, thanks to you. You where for the most part correct, thank you!! To all whom have taken the time to help, thank you and sorry for wasting your time.
The issue is my original sketch geometry was not on the same plane as the part. See attached picture. No idea how or why this happened, but none the less it did. I have officially spent hours on this just wanting to know why... LOL. Always learning I guess.
Once again, thank you all!
Respectfully, Sean
