Hello, I have been trying hard to figure this out on my own and by reading through similar forum posts, but I am still stuck.
Classic story- I am trying to edit my design by changing a parameter in a sketch, with the hope that being reflected to bodies.
My workflow for this design (my first CAD project) was mostly using Sketch-Project-Extrude, and a couple patterns. I am trying to copy an existing design in order to customize it slightly.
I am trying to edit the diameter of a hole, however the sketch lines were in purple, so from what I gathered I needed to "Break Link" in order to make them editable. This gave me a blue line which I could freely drag, but not the black numbers to type in an exact variable. I dragged it out to close to what I wanted (from 45mm to 48.225mm), but the subsequent extrusion is not reflecting this change. "Capture Design History" is on, and I tried doing CMD-Click which did not do anything.
I am stumped! Attached is the file. Any help or advice is greatly appreciated. Thank you!!
