Help needed, trying to make a cone with holes (like a cage)...
JuanDAyalde
JuanDAyalde
Almost like the title says. I want to make a structure that is basically a cone with the faces extruded inwards and the whole thing is kind of a cage but shaped like a cone. I made this in Blender but I want to make it in Fusion so that I have control over the hole size and the cone size:
Thanks!
Replies (7)
jhackney1972
I did not look at or use the dimensions from your STL file.  I am attaching an example model of the way I would probably create what you show.  If you have questions about my method and cannot determine them from the timeline, please ask me directly.  Model is attached.
John Hackney, Retired
JuanDAyalde
Thank you very much for the reply @jhackney1972 . That is definitely one way to do it. I was thinking maybe fusion had a feature that allowed to make holes across a face in a very one-click-change-parameters kind of way... Kind of like a grid/grill or lattice (I'm just throwing things out there at this point).
Still, I will try your approach and work on that for now, but if something like what I have mentioned that works comes to mind let me know. Thanks!
TheCADWhisperer
@JuanDAyalde wrote:
I want to make a structure…
Let’s back up a minute and discuss how the structure will be manufactured.
Simple 3D print?
Assembly of multiple components?
JuanDAyalde
Thanks for the reply @TheCADWhisperer. The idea is to make a 3d print. Originally the design is part of a water tower that serves as a vase for plants. Unfortunately the store that sold those is no longer available and I figured I would make them myself. The cone/cage is the top of the water tower. Here are the pictures of the original idea:
Warmingup1953
Don't forget the walkway!... What a fun project!Bunnell_Water_Tower_-_West_Side_View_of_Elevated_Tank.jpeg
JuanDAyalde
Hello everyone, just a quick update on the watertower plant vases. I have used the method previously suggested by @jhackney1972 and these are my results.
JuanDAyalde_0-1706274033357.pngJuanDAyalde_1-1706274051239.pngJuanDAyalde_2-1706274063937.png
TheCADWhisperer
@JuanDAyalde
Can you Attach your new file here?
I think there is an easier technique using Web.
Or maybe not.  I was thinking of another program.
