Announcements
Component Properties Box Constantly Refreshing
unitrakpowderflight
unitrakpowderflight
Hi all,
When I right click and select properties for a component, the dialog box is flashing/refreshing repeatedly; almost like I had a refresh key constantly pressed. Is this a known issue or is anyone else having this problem?
Regards
Nick
g-andresen
please show an animated GIF
günther
unitrakpowderflight
Interestingly when I looked to record the gif, and changed from full screen window the problem didn't happen, but when using F360 full screen it does. I've attached the gif to show the issue, however it only catches some of the repeat cycles.Recording 2023-11-24 at 14.21.33.gif
Phil.E
Thanks for posting the issue here and marking a solution. I'm curious what factor you determined is causing this? Also, when you say Full Screen do you mean maximized, or true "full screen" as enabled by this command?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
unitrakpowderflight
Hi Phil,
I'm not sure what is causing this. When I said full screen, I meant maximized, I have also found that it happens when the window is sized to fit vertically. I'm using Windows 11 and so if I got to drag the top or bottom of the window and it sizes to fit vertically - the problem also occurs.
If I use the enter full screen mode you asked about, the problem does not happen.
Regards
Nick
