When I attempt to open a 3D (.stl) object file, I get the error message "This computer's graphics driver or hardware may be limiting performance". I am using a DELL Latitude 7300 with the standard Intel UHD Graphics 620 card. Can anyone provide a link to a driver download that would make the software work on my system? If this is not possible, what additional hardware do I need?
Solved by jhackney1972. Go to Solution.
Not sure if this will help but it is worth checking. In the Graphics Diagnostic dialog, make sure the Limit Effects to Optimize Performance is checked. This dialog is found as shown below.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
