I'm working with a fairly large assembly (might be too big for fusion) and its been working okay for a while but now when I use 'Get all latest' it will update the model but the icon won't go away. It does actually update changes so its not the end of the world but the warning sign doesn't go away which is annoying and could cause issues if I'm not careful. Still great software though
Hi @basty46777, thanks for posting.
Possible cause of the issue may be that the Update Reference Manager is running in Fusion 360 background. You can check it and try to resolve the issue by following the steps bellow:
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Thanks for the help, but when I close fusion there are no instances in the task manager. Also a computer restart didnt fix it either
Hi @basty46777 ,
If you can share your project with us then, we might able to look into dataset and find the root cause quickly.
The project is quite big and there's lots of components so I cant share all of them but here is one of the parts that shows the warning when there's nothing to update. There's lots of parts glitched like this but not all of them. It happened when I used get all latest in one of the larger assemblies.
