Announcements
generate turning path with sketch
marco_bazzali
marco_bazzali
hello,
can I generate a work path for the lathe using the sketch alone?
and is it possible to do a single face and profile machining from the model?
thank you very much
seth.madore
Yes, for the most part, that should be possible. Do you have a sample you could share so we understand the extent of what you're trying to accomplish?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
HughesTooling
You can use just a sketch selected under Model in the turning op but the sketch needs to be pretty much what you'd draw for a Revolve feature so your not saving much using a sketch.
And you can set the front and back distances to restrict the cut to a single face or area.
Mark
Mark Hughes
Owner, Hughes Tooling
marco_bazzali
Classified as Internal
hello,
thank you for your reply, I have attached the sketch.
thank you 1000
