Fusion Support
Gear Joints
2 REPLIES 2
bigonvalue
413 Views, 2 Replies
Gear Joints
Got my gears working using a motion link ok. But I do not seem to be able to manipulate the assembly by clicking and dragging one of the gears. I can move the gears by double clicking the "joint flag"
See: https://www.dropbox.com/s/v7ws3d0jhou48d1/Gears.jpg?dl=0
But I don't seem to be able to simply click on the surface of one of the gears and drag to test the rotation motion.
I'm missing something but I'm not sure what.
2 REPLIES 2
hamid.sh.
in reply to: bigonvalue
Your components are jointed together but the whole assembly is floating, so when you drag (for which you need to have Select > Component Drag checked) everything gets dragged together. I only applied Ground to the subcomponent of Fix Lid Bracket and then dragging a gear works:
Fixing that component to ground might not be your intention, but the point is you should joint the whole assembly properly for it to work.
A few suggestions: do not Capture Position and apply joints instead. For creating designs work with design history on (it's off in some of your external parts). Also if I wanted to do this I would make those brackets inside this file, to take full advantage of Fusion.
Hamid
bigonvalue
Thanks. Completely overlook this step. And thanks for your other suggestions.
Kind regards.
