I know that fusion360 don't have Linux support and forum is not dedicated for Linux thinks, but I am running out of ideas and beginning to be hopeless so any idea was welcomed.
I have been trying to run fusion360 on linux for some time.
But I am not successful to run it in a somehow usable state.
I have tried it in Ubuntu and gnome-fedora from snap and from Autodesk-Fusion-360-for-Linux previously but with same result as now:
Issue: (I recorded multiple issues that I don’t know if are somehow connected).
Fusion360 throws a lot of wine errors. (QtWebEngineProcess.exe recorded problem):
When editing a sketch in fusion360 you can´t type into the dimension text input.
When fusion360 window is resized to bigger model area balckout.
install fusion 360 from Autodesk-Fusion-360-for-Linux
With command mkdir -p "$HOME/.fusion360/bin" && cd "$HOME/.fusion360/bin" && wget -N https://raw.githubusercontent.com/cryinkfly/Autodesk-Fusion-360-for-Linux/main/files/builds/stable-b... && chmod +x install.sh && ./install.sh
login into fusion360 using command:
wine "{userDirectory}.fusion360/wineprefixes/default/drive_c/Program Files/Autodesk/webdeploy/production/0b67cdf9b5e1511700618e51757ca1535bfaa4da/Autodesk Identity Manager/AdskIdentityManager.exe" "{link copied from browsers login button}"
Where {link copied from browsers login button} is login ling after authentication on fusions web because wine has a problem redirecting adskidmgr:/login….
used from git issue.
issue was replicated.
(QtWebEngineProcess.exe recorded problem is thrown even if you are not logged in.)
In the command line are some warnings, but I don’t know if they are connected to this issue.
Some warnings about DPI (at first i assumed that was not a problem, but this messaging is to often) and screen and folders.
wine: could not opeAutodesk-Fusion-360-for-Linuxn working directory L"unix\home\ogross\Plocha\", starting in the Windows directory.
wine: could not open working directory L"unix\home\ogross\Plocha\", starting in the Windows directory.
qt.qpa.window: SetProcessDpiAwarenessContext(DPI_AWARENESS_CONTEXT_PER_MONITOR_AWARE_V2) failed: COM error 0x5: Pøístup odepøen.
qt.qpa.screen: “Unable to open monitor interface to \\.\DISPLAY1:” “Úspìch.”
qt.qpa.screen: “Unable to open monitor interface to \\.\DISPLAY2:” “Úspìch.”
“C:/Program Files/Autodesk/webdeploy/production/0b67cdf9b5e1511700618e51757ca1535bfaa4da/plugins”
EnableNonClientDpiScaling() failed for HWND 0x1102bc (120) (Toto volání není implementováno.)
GetPointerType() failed: “Úspìch.”
If you are interested in full log there is : whole log
Machine specs
KDE Plasma version: 6.0.3
KDE framework version: 6.0.0
Qt Version 6.6.2
Kernel Version: 6.8.11-300.fc40.x86_64 (64-bit)
Fedora Version: 40
CPU: 6 × Intel® Core™ i5-8600 CPU @ 3.10GHz
GPU: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
Final question:
My question is what that could mean?
And what to try to solve this issues (or get more info whats going on)?
At the minimum, it sounds like WINE is having trouble processing the calls to enable Windows high DPI scaling support, in relation to your displays and EDID data. This normally uses the Windows COM (Component Object Model).
There are also failures initializing the embedded browser process, though that could be for any number of reasons.
Thanks for awnser.
I kinda solve this issue on Fedora forum (sorry fór not listing here).
I figured out that X11 working properly And probably Its problém with nVidia drivers.
