I'm trying to learn Fusion 360 ,since I already know Inventor, but I'm having really poor performance and bugs when using it.
It's not fluid and the data panel is not working at all.
My computer is new and has high performance parts
Here is the Dxdiag log :
Operating System: Windows 10 Pro 64-bit (10.0, Build 15063) (15063.rs2_release.170317-1834)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: 0807
Processor: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz (8 CPUs), ~4.2GHz
Memory: 16384MB RAM
Available OS Memory: 16326MB RAM
Page File: 8853MB used, 10289MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
Card name: NVIDIA GeForce GTX 1080
Manufacturer: NVIDIA
Chip type: GeForce GTX 1080
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1B80&SUBSYS_85E81043&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 16239 MB
Dedicated Memory: 8076 MB
Shared Memory: 8163 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: HP 2509
Monitor Id: HWP283A
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll
Driver File Version: 22.21.0013.8494 (English)
I'm using 3 screens, not sure if it could impact F360's perfs.
3 monitors vs 1 monitor could potentially make a difference in performance. More pixels requires more resources. You could try testing with 1 monitor to see if there is any change in behavior.
From the text you pasted in from the dxdiag, I wasn't able to see the graphics driver version date. However, if you haven't done so, it may be a good idea to update the graphics driver from the manufacturer's website.
With regards to the data panel issue, can you upload a copy of your diagnostic log files? There is a command in the help menu that will automatically gather them.
There's some suggestions that you may want to try.
The log files will give me some further information to go on. I'm wondering if anti-virus software may be blocking the adcefwebbrowser.exe process. There are some tips here that may help.
I look forward to your reply and I hope this helps.
I agree more pixels requires more resources but I play very recent games without issues, regarding AD softwares, I use Inventor and Revit without issues too
I'll try to deactivate them anyway.
Drivers are up to date and I tried giving high priorities to Fusion 360 process, no difference
I'll look and try the suggestions you gave me
I join the *.zip of log files
Thank you for your help
JPM
Edit: I did this procedure : https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t... and noticed I don't have any NsCloudBrowserCache_autodesk****.dat
There's an error in the log files I haven't encountered before.
0171027T143140 E CloudBrowser: No visible Project. ThreadID: 18964, Function: void __cdecl Ns::CloudBrowser::GroupCollImpl::downloadData::<lambda_3a211c5be94d76c8ec4ac70ed1dcaae2>::operator ()(class std::shared_ptr<class Ns::Network::Request>) const, Line: 319
Based upon some of the syntax, I believe the log files are recording an issue with network connectivity.
Is it possible to test temporarily disabling anti-virus software as a diagnostic procedure?
One other test you may try:
1. Open up your hub's dashboard
3. Upload a CAD file to that project
4. Restart Fusion 360 and retest the data panel
I hope this helps. Thanks for the updates. Please let me know if you have any questions.
So I uninstalled Bitdefender and tried, didn't change a thing
I deactivated windows defender , didn't change a thing
I uploaded a CAD to myhub and now everything works fine ( for now ) , even the poor performance is gone.
Reactivated Windows defender and still works fine
Do you have any idea why ? Just curious
Anyway, thank you for your help, I'll test it for some hours and give a final feedback
I have a theory that you archived or removed the default project that was created and there were no other projects in the hub. I'd have to do some testing to confirm (just a theory at the moment). Seems like an issue, if this is the case.
I am happy that that solution worked! Total guess on my part (even a broken clock is right twice a day). 🙂
One last tip on the performance side of things, there is a quick way to optimize the effects for performance. See the below link for more information.
