What is up with this new update? It has screwed up many things in my previously running programs. The last issue is a toolpath that has ran for 2 years, and I tried to edit it and I get this "eRROR: failed to open job". what is this? Also, I am trying regenerate a morph toolpath.
Also, the update messed up the pass through function under manual nc.
It has also messed up many of my previously working toolpaths in programs. Please go back to previous version or fix solution asap!!!!
Thanks for posting! We've seen some similar reports with Morph during this last update and have logged CAM-12461 to investigate further.
Does the same error reoccur if you recreate a new morph toolpath? If you'd like to share your part with me I am happy to have a look.
Thanks @banddspindles!
What happens if you try a new morph toolpath on the same geometry as the problem part?
If you could share your file with only me, I am happy to take a deeper look. To do so, you could direct message me a downloadable, password protected link.
Hi @Anonymous
Thanks for reaching out! I've added your file to our known issue on this problem behavior - thank you for sharing it!
I was unable to find a workaround using Morph in your file and would recommend using an alternative 3D toolpath like Parallel while this is investigated.
