Fusion is not saving changes
michele.frusi
Observer
Observer
michele.frusi
Observer
Observer
I've been working on a project for some time now, but in the last few days i keep saving the project and yet the changes i made to the object are not saved. Despite this the new sketches i draw are saved and the operations i made are in the timeline, what is missing is the physical modifications in the body. I can't keep doing the same stuff i made the day before and hope that when i save and close Fusion something is saved. I've been losing many days of hard work because of this.
What is going on? What can i do to solve this (very annoying) issue???
RajkumarIlanchelian
@michele.frusi When you state "physical modifications in the body" are not saves do you mean for example if you do an extrude it is saved in the time line but the model does not show/save the actual extrude?
Will it be possible for you to share this design with us?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Yes, for example when i make a loft, save the project, close Fusion, open Fusion, open the project, the loft is in the timeline but the body is still as before i made the loft. If i double click the loft in the timeline it opens it and i have to execute the calculation again to have it shown in the body.
Also i can export the project as .f3d, but when i try to open it Fusion says that the file is corrupted. I tried this 4-5 times and never succeeded to open the saved file.
This issue occurred also on another project a few months back. Since then i reset my pc, reinstalled Windows and Fusion.
@michele.frusi Would be open to inviting a couple of engineering team members into your project to investigate?
If so please email me at raj.kumar.ilanchelian@autodesk.com and I can send you the names to invite to the project.
Autodesk Fusion
Join Fusion Insider
Sure, i'll contact you via email
