So I've been trying to export a model so I'd be able to print it out.. I've finished designing and i'm working on exporting it.. When I export it and bring it into my slicer, (Slic3r Prusa Edition) It's very very tiny, I don't understand why and cant' seem to fix it
Solved by karina.harper. Go to Solution.
Hi @Anonymous
Check your units - are you in inches or in millimeters?
If you're in inches, convert to mm before exporting to STL. Most slicers use mm as default.
Let me know if that solves it for you!
Cheers,
Karina
Took me a bit to find out where to change that but it eventually worked out great!
Thanks a bunch!
