- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I'm having trouble with a design. This design consists of two components. When I open the design and move the mouse cursor over the first component, it should display its shadow in 3D. However, Fusion stops responding, and I have to close the software. It's quite frustrating to work with because this component is part of an assembly, and every time I need to move it, Fusion crashes. I discovered the latest version of the design where this issue doesn't occur, and the difference with the next version, where the problem arises, is the modification of the height of a referenced sketch on the origin plane.
I marked the component and the sketch that are causing the issue. On the right, I also highlighted some features that, if deleted, will also cause the problem.
