Fusion 360 is failing to update
Silvmdg01
Observer Observer
Silvmdg01
Observer
Observer
After several attemps, I am asking for your support on this.
jhackney1972
You will need to post your Fusion 360 log files.  If you do not know how to collect them, take a look at this article.
John Hackney, Retired
Silvmdg01
Observer
Observer
I thought these were added yesterday. Sorry
tasha.addington-ferris
Autodesk Support
Autodesk Support
@Silvmdg01 Are you launching from a desktop shortcut? If so, can you try this:
  1. Delete the current Fusion 360 shortcut.
  2. Open the Fusion service utility See How to launch the Fusion 360 Service Utility
  3. Run Repair Fusion 360.
  4. This will take the version to the latest and also generate a new shortcut. Use this new shortcut to launch Fusion.
Tasha Addington-Ferris
Autodesk Fusion
Technical Support
Autodesk Support
Autodesk Support
My guess based on your logs is that your shortcut is stuck launching an older version of Fusion but the newer update has already downloaded and is not being launched, so it fails to recognize that an update is available.
Autodesk Fusion
Technical Support
