HI there,
I installed Fusion360 2 weeks ago, and it worked twice since then. Have deleted and reinstalled it approx. 6 or 7 times, yet no luck. Have also used the terminal command which I found in the forum, yet no luck either.
/System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -kill -r -domain local -domain system -domain user
The icon simply keeps jumping up an down, the starter window opens until a software error message appears.
Running on a 15" MacBook Pro 2017, so should meet the minimum requirements.
Am at a loss on what to do next.
Thanks in advance
Solved by ryan.bales. Go to Solution.
First question, have you restarted your mac after any of the reinstalls?
Second did you do a Clean uninstall?
Third, are you using a the MAS version or the one straight through your account?
Hi Ryan,
thanks for your reply. So I found the error, and it had nothing to do with the install. Fusion360 works perfectly fine in my home wifi, over my personal hotspot (iPhone) but NOT through my office Wifi... had not tried it anywhere else.
We have another start-up sitting next to us, and they use it just fine (same network). Any ideas what I could do? My firewall is off.
I know this is not the topic above, so I could post a new question.
Kind regards,
Ben
This means there is something specific to their network that is blocking you (obviously) But what that is we need to find out. My guess is that its a proxy server or something akin to that.
This is the best place to start for those issues: Troubleshooting Network Connectivity Issues for Autodesk Fusion 360
Hi Ryan,
thanks for your reply. So as a workaround I am using a Ethernet cable, and it works just fine.
Thanks!
Ben
