I am learning to use Fusion 360 on my PC in the living room, I would like to have it on my laptop as well so that I could take it with me to my workshop (garden shed!). Is it possible to load it on two devices?
Solved by jhackney1972. Go to Solution.
Yes, you can use your same Autodesk Account and load Fusion 360 on two devices.
John Hackney, Retired
As @jhackney1972 said, you can load it on two devices. Actually though, you can load it on as many devices as you want! The caveat is though; per the EULA, you are only permitted to have one instance of Fusion RUNNING at any one time
